Isaacmaple08
Seeing these 2 DTCs, Airbag light is off, Airbag key is turned on, and Fuse 3 looks good. Should I buy another Airbag module? As I understand it, I'd need to initialize it with DRB if I do?
You are not telling us what you are doing. WHY are you looking at this? Did you change the module? Have you had issues of some sort, if so, what? What are you working on? NONE of us will recognize that ambiguous code, so try telling us the history here and perhaps we can put 2 and 2 together and give you an answer you can use.
You had to say it, so I had to respond, that's how the internet works:
Afraid to have my wife or daughter in the car if the airbags aren't working.
Why? I've been in two collisions since 2014. I was injured lightly in both crashes. BOTH times, my injuries came from the airbag deployment, not the collision.
Do not confuse a liability-mandated device (an airbag) with an actual safety device (a seatbelt or crumple zone). My airbag module in the car is bad and out of service, the one in my pickup has been disabled.
When I die and my son sells the car, the service history booklet says, on page 1: "The airbag module is disabled, the warning light is disabled and the airbags will not activate." (The truck will be dead long before then......)
