Ronman
Until you can see what the exact code is then you are just throwing parts at it. It could also be airbag in the steering wheel etc. It is also possible the part from the junkyard is defective, those modules go bad for no reason sometimes.
Yeah I've pretty much came to that conclusion as well thanks for the info! Looks like im off to buy a scanner that does the SRS codes.
