Thread: ac leak?
Old Nov 6, 2023 | 02:08 PM
GraphiteGhost
Default Re: ac leak?
Originally Posted by alawhon05@gmail.com
Today I turned on the ac and clear liquid started pouring out from under my glove box. Not just a little but i’ve put 3 towels down to try to soak it up and it’s still a puddle. I think it’s an ac leak but i’m not sure i don’t know anything about ac. looking for advice.
Sounds like the drain hose for the A/C evaporator is either missing or has been pulled up out of the exit of the interior. That hose drains out the water removed from the air by the action of cooling the air. Find the hose and insert it into the hole where it is supposed to drain outside the car underneath. I have no idea where it is installed in the ductwork below the evap coil but maybe someone else can point you to the right spot. Good luck!
