ac leak?
Old Nov 6, 2023 | 01:46 PM
alawhon05@gmail.com's Avatar
Default ac leak?
Today I turned on the ac and clear liquid started pouring out from under my glove box. Not just a little but i’ve put 3 towels down to try to soak it up and it’s still a puddle. I think it’s an ac leak but i’m not sure i don’t know anything about ac. looking for advice.
Old Nov 6, 2023 | 02:08 PM
Default Re: ac leak?
Sounds like the drain hose for the A/C evaporator is either missing or has been pulled up out of the exit of the interior. That hose drains out the water removed from the air by the action of cooling the air. Find the hose and insert it into the hole where it is supposed to drain outside the car underneath. I have no idea where it is installed in the ductwork below the evap coil but maybe someone else can point you to the right spot. Good luck!
Old Nov 6, 2023 | 04:25 PM
Thats no A/C leak, its a plugged condensation drain.
Sussudio
Sep 8, 2022 03:59 PM
No704
Jun 15, 2022 07:09 PM
utsilverfox
Jul 23, 2021 02:46 PM
rjoyner17
May 16, 2009 12:59 PM
Skyshadow
Apr 28, 2009 06:56 PM
