Old Nov 13, 2023 | 11:02 PM
M60A3Driver
Default Re: Horn not working? Suggestions?
Originally Posted by Tallulah
Hi There!
I'm having trouble identifying the Horn Relay. I believe its the one on the far left, but it looks different than relays in other cards. I know I've seen you can often times swap the horn relay with the rear defroster relay in order to run a quick test by switching them both and see if that works, but I'm finding it a lot harder to tell.
If I posed an image, would you be able to help further? Really appreciate your wisdom!
To note, fuses look good for horn.
Thanks again!
Tallulah
Hi, You do realize you're replying to a 10 year old post?
I think you can find replacement relays on e bay or contact tighed1 He's really good with these relays.
May I suggest that you make a new post in "Troubleshooting & Technical & Modifications".
Your post will get noticed more.
