Old Nov 15, 2023 | 08:03 AM
Robgauss's Avatar
Robgauss
Default Re: Top inoperable - where to start?
Thank you all for your thoughts on this. When I have access to the car will check these things out, starting with the divider position and then lowering manually the top with engine running and then trying to raise it with the switch. I have watched several videos snd will read through the detailed information above,
I really appreciate it and will let you know the outcome good or bad. Thanks again.
One other note - when I unlatch the D-ring the windows do drop down.
Rob
