Parisitic Battery Drain, TPMS Module
I have owned a 2006 Crossfire basic Roadster since 2007. Just recently it has developed a parasitic drain on the circuit connected to fuse 9 (TPMS, Security, Horn,Interior lights). Everything seems to work correctly and amperage measures change as different options are used. I can't test TPMS because the TPS sensors in the wheels were unknowingly removed when tires were replaced. I cant seem to locate the TPS module to disconnect it and determine if it is indeed the module. The hack found on YouTube suggesting disconnection of the gray yellow wire cant be used as I don't have a garage door opener built into the headliner.
Thanks in advance,
Dan
