Re: Help diagnose intermittent rough running
I can look at those 2 parameters while driving, but I don't know what to look for on the MAP reading to know it it is abnormal.
The filter/regulator should be correct they were both Bosch and matched the parts removed.... but if there was a fuel pressure problem I would assume I would have more issues with WOT than idle and part throttle.
As for the coolant sensor, where is it located, I can inspect it and the connection on it as I haven't looked at it yet.
