Old Dec 3, 2023 | 03:43 PM
jtammel's Avatar
jtammel
Default ABS ESP lights and front right brake acting up
Symptoms: Front right brake started to brake on its own intermittently. ABS & ESP lights were on on the dash. Faint grinding noise can be heard coming from the front.
Cause: Wheel bearing catastrophic failure and seizure that also damaged wheel hub assembly where the bearing is seated.
Fix: New wheel hub assembly and new bearings
Remember to replace those bearings before they fail as it can be costly to replace if wheel hub assembly gets damaged.
