Finally remembered to update the Links:
TPMS -
https://www.aliexpress.us/item/3256805575012064.html
OBDlink MX+ OBD2 Bluetooth Dongle for Torque -
https://a.co/d/hxbLc78 (This is an expensive one that updates a bit faster than regular ones, but you can buy a $10 ELM327 Dongle and it'll work fine too)
Torque/Torque Pro -
https://wiki.torque-bhp.com/view/Main_Page (Pro is like $5 in the app store, I think I bought it in 2012 and it's come in handy a ton of times)
TASKER -
https://tasker.joaoapps.com/ (I use this to kickstart the apps I want running in the background, IFTTT might work but I read that on radio's it may not work since it put all apps to sleep. IFTTT is a lot easier to use)
RCA Grounding Mod - Yes this looks Ghetto as hell, Yes it works, Yes most every android Radio I've had has had alternator/engine noise if using an external amp. The RCAs are all poorly grounded. This 8.8 unit has a SPDIF/Digital out so If you have a high end amp or DAC just use that to avoid this. I just connected them to the Ground wire for the radio and it fixed the noise.
RCA Ground mod on a pioneer unit.
