Joying 8.8 with Backup Camera
Old Dec 12, 2023 | 09:15 AM
type dougie's Avatar
Default Re: Joying 8.8 with Backup Camera
I don't think anything else was needed however Rudy did the install of mine did require moving a couple wires on the harness. I am not sure what he moved unfortunately.
Old Dec 12, 2023 | 10:10 AM
Isaacmaple08's Avatar
Originally Posted by Southernscrew
Hi, Bought this unit and can't find the wiring harness , Which one or where did you all get yours?
Thanks, Ken
Mine already had the wiring harness. from a cheap JVC when I bought the car. However per this post You'd need Metra Harness 70-1786 Mine had the VW & Audi one so I swapped the Hot and Ignition wires.
Sounds like you bought the Metra Harness 70-1786 (RCA plugs). You won't need to swap the Red & Yellow wires. That only happens if you bought Metra Harness 70-1784 (w/o RCA plugs). The 1784 harness is for VW & Audi applications, but can be used on M-B & Crossfire applications if the Red & Yellow wires are swapped. The 1786 harness is an update and it is no longer required to swap the wire colors on M-B & Crossfire applications.
You probably ought to review the attached DIY from Forum Member GregWork. His DIY write-up was one of the most straight-forward I came across regarding hooking up an after-market stereo to the Crossfire. (Note: Not sure what differences exist between the Infinity unit with or without NAV.) The Scosche VW01B wiring harness is identical to the Metra 70-1784 - both have no RCA connectors. Per pizzaguy, these wire harnesses enable you to direct-wire the speakers in the Crossfire.
Old Dec 12, 2023 | 10:59 AM
Southernscrew's Avatar
Thumbs up Re: Joying 8.8 with Backup Camera
Thanks Guys,
I think I got it !!
Ken
garlum
Apr 3, 2009 04:40 PM
spiitz
Mar 2, 2007 01:10 AM
Fritzauf
Feb 6, 2007 03:08 AM
Eracer76
Oct 2, 2006 08:32 AM
MARK_UK
Aug 12, 2003 05:29 PM
