Old Dec 15, 2023 | 09:53 AM
svtmerc's Avatar
svtmerc
Default SKREEM Turn Signal Flasher Relay Issue
So my passenger side turn signal/parking light operates normally with the light switch turned on, as well as when the turn signal is on, but when I use my key fob to lock or unlock, the drivers side light will flash but the passenger side won't... Any ideas as to the cause?
Moderator Note:
This thread is made a "sticky" because its a rare issue that involves a hard to find part. I was shocked when I managed to find new relays. Please read thru the thread at least to post 16 to understand what Im' getting at.
Post 16 has a link to the relay if you need one. It was HARD to find but it IS available, not locally but still....
Thread title edited for better search performance. --- Pizzaguy
