Old Dec 18, 2023 | 04:47 PM
pizzaguy
Default Re: Climate control **** alignment
I completely agree with onehundedr80's feedback above. I made getting the shafts re-inserted into their respective spindles a little easier by using some split corrugated wire loom to extend the spindles for re-alignment. Took me a couple of tries, but worked like a champ & no need to remove the wire loom afterwards.
WOW. I never thought of that.
Something that also might help is to remove the center console HVAC vent located directly above. Gives you some improved visibility & access when re-installing the HVAC Control Module.
Probably not needed with your wire loom idea.
