Old Dec 21, 2023 | 01:24 AM
M60A3Driver
Default re: SKREEM Turn Signal Flasher Relay Issue
Originally Posted by svtmerc
So my passenger side turn signal/parking light operates normally with the light switch turned on, as well as when the turn signal is on, but when I use my key fob to lock or unlock, the drivers side light will flash but the passenger side won't... Any ideas as to the cause?
I'm just throwing out guesses here... Do you have a second key fob, if so have you tried it with that? Do you get the same result? Have you tried checking the wiring to the bulbs, or the fuses related to those bulbs?
