Old Jan 1, 2024 | 10:21 PM
GannyX's Avatar
GannyX
Default Re: Leaving Key in Ignition Switch
OK, I finally got around to it. My standby drain:
  • Key not in ignition two minutes after shutting car off - 17mA.
  • Key in ignition two minutes after shutting car off - 17mA.
Not a hard test to do and I already knew what the result would be, but it's always a good idea to verify before speaking.
I expected someone else to beat me to the punch, the fact no one did is part of why I dont' spend as much time here these days.
Sorry I was sleeping from my drive back from Florida (all nighter) but anyways, the only time it makes a difference is trying to lock the door while the transponder inside of the antenna ring . Car will not lock for 15-30 mins. ( I tested a bunch of time, why I against placing the Transponder inside for pushstart)
