Old Jan 3, 2024 | 11:19 PM
GraphiteGhost
Default Re: OBD port connection
Originally Posted by willyp
Thanks much, think I'll order the scanner only, once I get to go over the srt I can always order the adapter if needed. I sure hope to enjoy it!, barring snow should be here Monday, think I lucked out, 05 srt6 coupe 10900 miles, so hopefully won't need the scanner right away lol
Good luck with the scanner. Truth be told, this is the first time I ever heard of this scanner you referenced. Many will tell you something will work to make a sale so make sure you confirm return options if it isn't what the salesman said it was. I have 2 CRP-123's (older one and the newer CRP-123e) that cannot read my airbag (SRS) module, but cannot yet connect to anyone who has one that works that can verify the two I purchased were bad or not. Good luck!
