Old Jan 4, 2024 | 11:10 PM
pizzaguy
Default Re: Secondary air injector motor
Originally Posted by eseel
I had a check engine light come on and the code seems to be a secondary air injector motor. I have seen multiple part numbers. Can anyone tell me the definite part number for an 06? Thanks in advance for any help.
That motor does fail, but most of the time, it's the solder at the connector on the RCM or the relay on the RCM. You can disconnect the wires and jump it to 12 volts, if it runs, then it's not the motor.
