Old Jan 15, 2024 | 01:22 AM
TKDMarine's Avatar
TKDMarine
Default Re: Convertible top won't open :(
So i had a shop read the codes for the top. They said the car is throwing the following codes:
9919 power top switch open to ground
9009 power top control module low voltage
9930 unknown top position
​​​​​​Rear bow switch sense circuit short to ground
they also toalsoe the trunk light did in fact turn off when the trunk was closed. The did adjust the latch catch on the trunk they told me they moved it up a little bit. I also added fluid to the reservoir.
