Old Feb 3, 2024 | 01:50 PM
GraphiteGhost
Default Re: Installing LED Headlights
Originally Posted by cabo
Has anyone use the SEALIGHT LED light bulbs?
I ordered them and am assured by the company that will work with the XF. The new bulbs are their X5 model.
Now the question, Instead of a single tab on the unit it has 2 tabs 90% apart. I am replacing H7 bulbs with a single tab.
I called the company thinking this must be a simple question for them to answer, but no they had no idea.
So has anyone else had this issue of which tab to use to line up in the housing.
Best to add a couple of pictures so we may see exactly what your saying OR rely on the seller since it is hard to see what your referring to. If they don't reply, it might be a good indicator if you have future trouble with them in the future (IF you even get them installed). I've looked them up, you might have to compare the ones taken out comparing the base of the new ones you purchased, to see how you line them up correctly. IF they do not match correctly (cannot tell from the website) then you might have to send them back. Good luck!
