Old Feb 4, 2024 | 12:10 PM
GraphiteGhost
Default Re: Installing LED Headlights
Originally Posted by cabo
You will note in the picture that there are 2 tabs. One would place the light in a vertical position and the other in a horizontal position.
I have changed bulbs before with regular H7 Sylvania bulbs with one tab.
The company says these are the right bulbs but do not specify proper position of the tab.
I will probably send them back.
I am desperate for more light.
I see what you mean, you are talking about the actual lamp inside the housing as it is flat and will either sit horizontal or vertical based on the tab location in the housing. That would concern me as well. Maybe, try both and see which one gives you the best light pattern. The seller should know which direction the actual LED segment sits inside the lamp housing, it seems. If you don't get an answer from them, yes I agree you probably should send them back. Good luck!
