Old Feb 7, 2024 | 01:48 PM
pizzaguy
Default Re: Infamous lifter/rocker arm tap
Originally Posted by red_2005_convertible
I've have, what to me, sounds like valve clatter, but when I use a stethoscope to listen to the valves, they sound find. I haven't found out what's making the noise, but I've read that it might be a solenoid in the EVAP system. Maybe that's symptom is part of bullet f. above.
It's not.
1) Valve noise happens, generally, every other revolution of the engine as the valve operates and varies with engine speed.
The EVAP solenoid you are thinking of is on the fender wall, near the brake controller, and it activates at a steady rate, regardless of crankshaft speed.
2) I know Cliff personally, I can assure you that Cliff knows the difference.
