Thread: Oil quanity
Old Feb 13, 2024 | 11:04 AM
onehundred80
Default Re: Oil quanity
Originally Posted by dadog6575
Butch here, I have a 2005 Crossfire convertible limited. M y question is the manual states 8.5 qts. however, when 8.5 is put in with filter change, I get an OIL indicator with an arrow pointing up. Have to suck out about 1 1/2 quarts
That seems excessive, I would guess you are not removing enough oil initially. Which method of oil removal are you using?
I use the vacuum level, remove as much as I can one evening and let it drip into the oil pan overnight, it is surprising how much oil I can get out the next morning. I can put in 8 litres, the oil level will be 1/16” over the full mark, but not enough to worry about. I found this out when I had 8 one litre bottles.
I have the car on the flat with 2 x 4s under the driver side wheels.
