Thread: eletrical issue
Old Feb 21, 2024 | 10:45 AM
pizzaguy
Default Re: eletrical issue
Originally Posted by dontbreak
thanks for pic yes that wire loom going into that fuse box on side next to battery in picture is the one i found that if i wiggled it things would come back on. was wondering if any body knew from symptoms i was having what circuit it would be to look for would assume its a supply power circuit if killing every thing.
When symptom occur.
1. dead car nothing has power key fob wont work either.
2. car stalling at stops in gear car is an automatic does not do this all the time.
Download the service manual from this forum, and follow battery feed to:
1 )The RCM
2) The tiepoints in the fuse box, driver's side, underhood.
I strongly suspect this is not actually in the box that contains the RCM (altho it could be). The 200 amp feed off the battery terminates both in the box that holds the RCM but also at the driver's side fuse box tiepoints. DO NOT make this harder than it is, the failure is right in front of you, it's just tricky to isolate.
In fact, you may very well be able to track this down without the manual, as moving wires around causes the failure. But if you study the wiring diagrams and take note of what goes out (headlights, radio, instrument panel lights) you can logically deduce where the failure is.
