Old Feb 23, 2024 | 03:28 PM
pizzaguy
Default Re: Top wont open/close - back wont raise high enough
Originally Posted by AnalogRob
Sure thing, it is fully out of teh latch from the trunk as I am able to get my arm under it. I have to go take care of some stuff but I'll get a pic when I get back. Until then, for a visual, the bow doesn't pass the headrest bars.
Just raise the bow by hand, if you encounter resistance that prevents this, you either are too afraid to PUSH it up, or the system has pressure on that cylinder - which It shouldn't.
To make SURE all pressure is GONE, pull fuses 5 and 6 from the underhood fuse box, this removes ALL power to the pump module, all solenoids will relax, and the valves from all cylinders to the tank will open.
Without power, there can be no pressure unless you have a frozen solenoid and in fourteen years here, I've never heard of that happening.
