Old Mar 1, 2024 | 04:51 PM
pizzaguy
Default Re: Turn Signals Stopped Working
Originally Posted by jimi72
OK...let's try this...
I'm having an issue you may be able to help me with. I have a 2007 Crossfire Coup, 6 Speed, that has lost its turn signals and hazard flasher. It all started when I got a CD stuck in the CD player. I removed the radio, unplugged the radio and removed the stuck CD. I stupidly did all the without disconnecting the battery. Nothing got shorted, no sparks, no smoke, no harm, no foul. So, I thought. Later when I decided to get back in the car and take it for a spin, I noticed I had no turn signals. I checked the hazard flasher, and it didn't work either. I have checked every fuse in the car with no luck. The Computer Control Relay is new, so I ruled that out. All bulbs are new as well. I mean ALL bulbs. It just seems odd that after the stunt I did with the radio/cd player that I lost my turn signals and hazards. You would think I blew a fuse, but they all check good. I even replaced some that I thought might check good but may not be. I'm lost at this point. Need help.
The thing is, with the turn signals and hazards, they both are fed power thru the Hazard switch* AND they share the same flasher module, which is on the BCM. If all you messed with is the center console "stack", and if BOTH worked before and both did not work after, I'd think you managed to compromise the wire from Console switch group pin 5 to C3 pin 46 on the BCM.
*This is not a typo, both are powered thru the Hazard switch. When the button is OUT, power is from fuse 4 on the ICM (Illumination Control Module, fuses are on driver's end of dash in North America, open drivers door for access). When the button is IN, power is fed from fuse 35 in the underhood fuse box, driver's side. Path is thru the Hazard switch, to the BCM, then back to BOTH the Hazard switch and column stalk (multifunction switch).
I think what pizza means is, when you click the stalk either way, does anything show on the dash where the 'arrows' are (lamp light)? Does the emergency flashers work when the red triangle on the forward console work (lamp in the button, and the two arrows in the dash) light. If working the flashers, do the outside bulbs on fenders in front/rear light? This I believe may locate a bad turn signal stalk. Please check carefully the flashers operation and dash indicators, as asked, and come back here with the results? Good luck!
This is a different guy than who I asked those questions of, but the answers DO apply here as well.
Also, rear side markers as well as front side markers work.
They are in no way connected to the turn signals or hazards.
