Re: NO HI beams
The hi beam flash failure is most likely the internal contacts of the Combination Switch being worn and dirty. Not being able to turn on your high beams is probably dirty and worn internal Combination switch contacts and/or the Illumination Module not supplying 12V to the Hi beam circuit.
