NO HI beams
Old Mar 12, 2024 | 09:21 PM
Gray Ghost's Avatar
Default NO HI beams
No High Beam lights
Fuses are good; have low-beams and fog lights.
No "HI beam light indicator" in dash
Most likely problem?
Thanks, Bill
Old Mar 12, 2024 | 10:48 PM
CyberCG's Avatar
Default Re: NO HI beams
The hi beam flash failure is most likely the internal contacts of the Combination Switch being worn and dirty. Not being able to turn on your high beams is probably dirty and worn internal Combination switch contacts and/or the Illumination Module not supplying 12V to the Hi beam circuit.
Old Mar 12, 2024 | 11:04 PM
Originally Posted by Gray Ghost
No High Beam lights
Thanks, Bill
One thing to try is "flash to pass", that is, if you pull the arm towards you, do the high beams come on? If they do but regular high beams do not work, then fuse 32 is blown OR the multifunction switch is bad.
If Flash to pass does not work either, I'd look at fuses 3 and 5 on the ICM (Fuses on end of instrument panel, below the cover that you access by opening the driver's door).
A bad multifunction switch generally fails on one side or the other. If NEITHER function lights the lights, I'd suspect trouble elsewhere.
If you had airbag or steering wheel (clockspring) work done, I'd suspect the connector to the multifunction switch did not get plugged in all the way when they finished work.
Old Mar 13, 2024 | 08:37 PM
red_2005_convertible's Avatar
#1 Crossfire Girl
Jan 24, 2023 01:08 PM
Furgal
Jan 31, 2014 04:29 PM
05cxfire
Feb 8, 2012 05:52 PM
crossfire08
Sep 7, 2009 05:17 PM
grphtmtlc11
Jun 26, 2007 06:39 PM
