Old Mar 19, 2024 | 07:46 PM
M60A3Driver
Default Re: top problems...episode 1,000
Originally Posted by loudrango
i checked around before i posted and i couldn't find anyone else with the same exact problem.i already had my windows down...went to put the top down and the windows went up half way then i couldn't hear the pump anymore.checked fuses and fluid is full.i know the xf's are finicky with electrical...could it be my batt terminals are a bit corroded and or dirty causing the problem?
A low battery will cause a lot of weird problems. Mine was low and when I went to start my car my wing went up and the car started beeping.
Did you have the car running when you tried to put the top down? There could be a few things that could cause that. You're module might have lost track of where your top is supposed to be.
Try cycling your top manually. All the way down and then all the way back up. Check out the video in the link:
Also to prevent corrosion use these felt terminal rings. You can get them at any auto-parts store:
