Old Mar 26, 2024 | 10:33 AM
xintersecty's Avatar
xintersecty
Default Re: Radio cuts out, except for bass!
Originally Posted by LBBUZZ
All wiring to the amp seems secure, and in fact it played fine when I had the amp "out", but not when driving. Seems like a bad connection somewhere?
Help! LBBUZZ in Laguna Beach 2006 coupe. I have checked the amp, as much as you can just fiddling with the connection once it's tilted up from under the passenger footrest. Come on, somebody, where's the loose connection I need to fix??
OK it helps to understand how sound systems work. Some of the speakers are for base and some of the speakers handle the midrange and upper ranges. I do know there are two big speakers, one each door that seem be for low frequencies. So the path is as follows: from head unit to amp, left and right audio. The amp breaks out the left and right into the different frequency groups and then to the speakers.
So if you check the connections at the amp, then you need to check the connectors from the AMP to the speakers.
