Old Mar 27, 2024 | 08:33 PM
onehundred80
Default Re: Central locking pump issue
Yeah, that module look fried. When you get a replacement, also get the harness with about 24-36 inches of wire with it (as water sucks up into the wires and it will cause problems down the road). .
Water does not wick up the wire as they are extruded together when the plastic shrinks it grips the wire.
The problem is corrosion on the original plugs.
