Old Mar 28, 2024 | 01:05 PM
GraphiteGhost
Default Re: Central locking pump issue
Water does not wick up the wire as they are extruded together when the plastic shrinks it grips the wire.
The problem is corrosion on the original plugs.
Not true, strip chronically wet wires and you'll find corrosion up the wires. You should know this.
