Old Mar 28, 2024 | 10:05 PM
M60A3Driver
Default Re: there is fuel in the charcoal canister !
Originally Posted by Anthony C
onehundred80 If your suggesting the fuel filter is / may be bad we will cut that thing open. new fuel filter on order.
I seen the other post with the leaking canister.
thanks for the tip.
I just had a similar situation with my 2006 base roadster. It turned out to be the gas cap. I had replaced it with an aftermarket cap. I had 3/4 of a tank and the gas light flashed. I reseated the cap and all was good for a weak.
Then it flashed again and the Check Engine light came on. I put the original cap back on and no trouble. You might want to try a new original Mercedes cap. It would be cheaper than the filter.
