Thread: No crank issue
Old Apr 1, 2024 | 08:43 PM
pizzaguy
Default Re: No crank issue
Originally Posted by Lilyeti
Hey everybody , I’m new to the CrossFit e world and could use some help, I recently picked up a07 convertible pretty cheap because the owner lost the key, I purchased a used ignition w/key the Skreem module and ECM to match, after installing them it would turn over but not fire , none of the dash light or fuel pump would turn on, it would do this two more times and then not at all , I know that is a screen issue, hooked up the alter scanner and it said no connection to ecm, I put the OEM ECM back in, dash light and fuel pump work but it won’t turn over, pulled the RCM and nothing looks dark but it does have a bit of a burnt smell, any advice on where to start would be much appreciated, the car is a 07 convertible , auto trans and has 75,000 on it
THe log shows he has not been back to see our posts. I've taken some time, I think I see whats going on. Perhaps this will help when he checks in again.
1) He buys the car, on the basis that the "key is lost".
2) He buys an ECU/SKREEM and key from a donor car (not a good idea, but some have had to resort to this).
3) The car turns over but wont run. He gets two cranks then nothing. This means he bought a non-matched set or a set with a bad SKREEM. BUt it also means the RCM is good cause the starter does engage.
4) Putting the old parts in, he gets no crank at all but this is, again, NOT the RCM cause we already know the RCM is OK.
Conclusion:
He bought a non-matching key/SKREEM/ECU set or a set with a bad module.
Other conclusion: THe original ECU appears to have a problem.
REcommendation:
He call the MSS and talk to James and send all items to the MSS and let them return a working set to him once they fix one set or the other.
That is how I'd do it.
