Old Apr 8, 2024 | 12:43 AM
  #43 (permalink)
M60A3Driver
Default Re: My Journey with my 2006 Roadster "Svengoolie"
Originally Posted by Gkayaker
How did you ID and prioritize your maintenance projects. I.E. were shocks replaced due to ride/handling, leaking, 46k miles, etc.
Just beginning a similar journey with a 32k SRT Roadster and would appreciate your insight.
Hi, thanks for asking.
I was doing preventative maintenance. My car is all original as far as I can tell. Nothing has been changed on it except the oil, oil filter, and air filters.
When I brought the car home the first things I replaced were the oil filter, oil, cabin filter and air filters. when November hit, I put the car up on jack stands and made a list of everything I wanted to change. Safety items were the first priority.
I knew the car was going to be in the air for a while so I just did everything that required the wheels to be off. (Shocks, brake pads, brake discs, brake hoses, Steering stabilizer, ground wires, replaced differential oil, flushed the brake and clutch fluids).
I will be posting more soon: Breather cover gaskets, valve cover gaskets, spark plugs & plug wires, coil wire plugs, idler pulley, tensioner, serpentine belt, tensioner shock (manual cars only), breather hoses, windshield replacement, and more.
If I can help in any way let me know.
John
