Old Apr 16, 2024 | 08:19 AM
andy2m's Avatar
andy2m
Default Re: 2005 roadster top hydraulics
Originally Posted by Oldschool
The hydraulics have been replaced, and after some fussing with reprogramming (thank you forum) it works perfectly. The video at top hydraulics is fantastic. I sent in my cylinders first to save on the core charges. I did mess up on sensor locations, but was able to troubleshoot my way through the problem via top hydraulics install videos.
Now, if the rain would just stop.
I got my 2005 xfire with 50k miles a couple years ago and the top did not work. The prior owner said the seals were leaking and he did not want to fix them. He was right, the top does not work but there is no leaking, presumably because there is not enough fluid left to leak. In any case, I did not have time to deal fix it but I did research the issue here in the forum and watched the Top Hydraulics videos. I still need to convince myself the prior owner was correct about the issue being leaky seals but it seems likely he was right and I will have to replace all the cylinders. Can you tell me how much time you spent doing yours? That might help me decide when to take it on. Thanks!
