Old Apr 17, 2024 | 07:31 PM
dedwards0323
Default Re: Quick Wheel Spacer question
Originally Posted by racerherbie
I am running stock tires up front but wider in the rear (285 35 19) in the rear. My question is would front wheel spacers help the handling. It's a bit "wiggly" when cornering hard. If so would you go with the 10mm or 15mm (needswings.com).
Thanks,
Greg
Originally Posted by amx1397
I think you should look at your steering stabilizer. if that is worn out , in hard turns it will wiggle , or you can over ride that with more power.
The above is really good advice. The Steering Damper is basically a routine maintenance item to change if you drive the Crossfire as a daily driver and/or put high mileage on the car. IMO It's cheaper than changing the oil & filter. Back when I bought my Coupe in 2008, the Steerng Damper probably only cost $15-$20. Not sure what it is now - I bought 2-3 of them back when they were fairly cheap & put them in my Crossfire parts bin.
