Quick Wheel Spacer question
Old Apr 16, 2024 | 01:53 PM
racerherbie's Avatar
Default Quick Wheel Spacer question
I am running stock tires up front but wider in the rear (285 35 19) in the rear. My question is would front wheel spacers help the handling. It's a bit "wiggly" when cornering hard. If so would you go with the 10mm or 15mm (needswings.com).
Thanks,
Greg
Old Apr 16, 2024 | 04:46 PM
Default Re: Quick Wheel Spacer question
Thanks,
Greg
I do not think so but if it feels good, do it!
Old Apr 17, 2024 | 07:10 AM
Thanks,
Greg
While I personally don't have your setup on my 2007 Coupe, I do know of several other Crossfire Owners that run the larger tires on the back without reporting any handling issues. Hopefully, one of them will chime in on your thread.
Old Apr 17, 2024 | 08:41 AM
I think you should look at your steering stabilizer. if that is worn out , in hard turns it will wiggle , or you can over ride that with more power.
Old Apr 17, 2024 | 07:31 PM
Thanks,
Greg
The above is really good advice. The Steering Damper is basically a routine maintenance item to change if you drive the Crossfire as a daily driver and/or put high mileage on the car. IMO It's cheaper than changing the oil & filter. Back when I bought my Coupe in 2008, the Steerng Damper probably only cost $15-$20. Not sure what it is now - I bought 2-3 of them back when they were fairly cheap & put them in my Crossfire parts bin.
Old Apr 18, 2024 | 10:22 AM
I just installed a Bilstein steering stabilizer. It costs more than the regular ones, but the quality is much better in my opinion.
I got it from FCPEuro. It has a lifetime warranty.
https://www.fcpeuro.com/products/mer...mper-18-140651
Buchacho
Jul 9, 2015 04:13 PM
NickyO429
Jun 24, 2012 09:45 PM
Wedge
Jun 3, 2009 05:50 PM
lightningryan
Oct 3, 2007 01:14 PM
Cyril Baldwin
Apr 8, 2005 11:06 PM
