Question? Steering wheel wobbles
Old Jun 23, 2012 | 02:19 PM
NickyO429's Avatar
Default Question? Steering wheel wobbles
I just put 20x8.5 in. wheels on front tires are 235/35/20 with 2 5/16 in. spacers on each front wheel, Rear I put 20x10 255/30/20 tires on rear with no spacers. Needed spacers on front to prevent rubbing on inside of tire. Don't know much, about how to fix the problem. Mayber realignment, not sure, but when I hit 40-50mph the steering wheel wobbles violently. I checked the lugs and they are torqued properly. I'm really lost and frustrated someone please help. Thanks
Old Jun 23, 2012 | 02:29 PM
MoparFreak69's Avatar
Default Re: Question? Steering wheel wobbles
Is that one spacer that is 2 and 5/16" thick or 2 spacers that are 5/16" at each wheel? Either way, neither is a good idea at all. Are any of the spacers hub-centric? Our cars support the wheels by the center of the hub, not the lugs. If you are just using regular spacers you are driving very dangerously.
Old Jun 24, 2012 | 09:39 PM
NickyO429's Avatar
I took the fronts off, should I go with h and r hubcentric or eiabach spacers and if so should I also get hubcentric rings for all 4
Old Jun 24, 2012 | 09:45 PM
All 4 spacers need to be hubcentric. As long as they are hubcentric and kept properly torqued there shouldnt be any problems using them safely. The only thing you need to keep in mind is that spacers can place extra load on front wheel bearings. Keeping up on servicing the bearings along with careful inspection while servicing them will alleviate any problems that might crop up.
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
da pink
Aug 12, 2015 05:20 PM
princepenson
Jul 29, 2015 07:44 AM
Blackout317
Jul 7, 2015 08:38 PM
