Old Apr 25, 2024 | 11:14 AM
Whitexfire84's Avatar
Whitexfire84
Default Two lonely wires can’t figure out where they go! Help
Hello everyone. I have two wires and I can’t
Wires are coiled up in my hand, but you can see where they lead to on the junction. Please help.
figure out where they go. They come from a junction behind the driver side headlight, and the picture you should be able to see exactly where they’re coming from. It’s two wires one wire is brown with the red stripe and the second wire is a solid brown any help would be greatly appreciated, I have no working horn and I’ve checked the airbag steering wheel connections are tight connections to the horns themselves are tight horns are new and not sure where these two wires lead to and if they may have something to do with my issue, all fuses are fine. RCM needs work , these wires are similar to the wires that to the horns themselves. That’s why I’m not sure if this may have something to do with my issue if someone can verify in their own vehicle where these two wires lead to I’d be greatly appreciative thanks for the input.
