Old Apr 28, 2024 | 10:16 PM
Ronman's Avatar
Ronman
Default Re: Mystery Hole in Firewall Underneath Brake Booster
Originally Posted by Pkrook
So, I found the red cap to a positive battery cable hastily glued into a mystery hole (OE in origin) on the firewall right below the brake booster. The question is as follows, is there a body plug for this hole that is simply missing or is there some equipment that should be installed that simply isn't? Could be a knockout for a third pedal given the position. Pics to follow...
Yes there is a body plug that goes there if it is an automatic, if it is a manual then that hole is used. At the factory if it was an automatic sometimes they put the body plug and sometimes they didn't.
