Old May 1, 2024 | 05:06 PM
Mostafa Rostom's Avatar
Mostafa Rostom
Default Re: Electric Nightmare - ASAP ( alternator keeps blowing and a fuse)
What 50 amp fuse blew? YOu've got to tell us what fuse is blowing, then we just look at what the fuse feeds to see what our issue is.
Also, the car looks awfully rough, if it sat a long time, it may be that rodents have chewed the insulation off a heavy cable (like the cable from battery to starter to alternator) and it's contacting ground - that would be kinda rough on an alternator.
The yellow fuse below out. The car was parked in open ground during the winter and water got thru it. There is power when the ignition is turned ON but no clutching or engine running.
