Mongoose57
H..... "Also will a leaking multi pin connector to the transmission cause the P0715 code thanks Mongoose57"
IF the transmission connector is leaking, and the fluid wicks up into the TCM,
you'd better correct that before it (the transmission fluid) makes it to the TCM. Too many TCM's have been ruined by this leaking connector wicking transmission fluid into the TCM. I believe your TCM is located under the center console. Good luck!
