Old May 22, 2024 | 04:07 PM
Nelson G's Avatar
Nelson G
Default Re: My H7 bulb headlight saga
Here is what I purchased. I will tell you I used clear lights for the marker lights because they look better than when I purchased the amber and red ones. The trunk light is different than the glove box light even though LastFit said it was the same. This is the thing I found out in buying the bulbs because the car is 3/4 Mercedes and 1/4 Chrysler some of the light fixtures are not the same as stated.
I did not use Amazon but purchased from LastFit they were very helpful and when something did not work out they replaced it at no cost. Can't beat great customer service and the cost was the same.
I will say I occasionally get a bulb-out signal (backing up) but after driving a while it goes away. I have not had any other problems and I am very happy with the LastFit LEDs. At night they light up the road, I live in a rural area and I am old so they work well for me.
And don't forget the headlights have a certain way that the tab needs to be put depending on if they are used for the headlights or the high beams. So watch this video:
Also, there is a way to replace the small marker lights in the headlight compartment. Here is the link: https://www.crossfireforum.org/forum...t-cluster.html
I hope this helps you. Take your time and you will be very happy with the results. I am.
9006 LED Bulbs Fog Light 60W 6000LM 6000K | LCair Series, All-in-One Design × 1
H7 LED Bulbs 50W 5000LM 6000K | LCair Series, All-in-One Design × 2
1157 2057 2357 7528 Red CanBus LED Bulbs Turn Signal Brake Tail Lights | Error Free Anti Hyper Flash, T3 Series Upgraded Version × 1
1156 1073 7506 1141 LED Reverse Backup Light Bulb | Xenon White, 2 Bulbs × 1
BAU15S PY21W 12496 CANBUS Error Free Anti Hyper Flash LED Turn Signal Lights | Amber Yellow, 2 Bulbs × 2
8 Colors License Plate Dome Map Side Marker T10/ 168/ 194 Bulbs | CANBUS Error Free, 1 Pair × 2
168 194 2825 T10 CANBUS Error Free LED Side Marker Lights Dome Map Bulbs | Amber, 2 Bulbs × 1
T10 194 168 CANBUS Error Free LED License Plate Dome Map Trunk Cargo Light Bulbs | White × 1
36MM 6418 6411 DE3423 LED Dome Map Trunk License Plate Light Bulb, 2 Bulbs × 1
39MM DE3425 6461 LED Dome Map Courtesy Trunk Light Bulb, 2 Bulbs × 1
