Old May 25, 2024 | 12:40 PM
  #83 (permalink)
M60A3Driver
Default Re: My Journey with my 2006 Roadster "Svengoolie"
H7 Lasfit Headlight Installation
Svengoolie sees the light!
March 1, 2024
Driving at night with the original halogen bulbs was terrible! I couldn't see very far in front of the car at night.
Soon the animals would be coming out,and I didn't want to go head to head with a deer. After checking the forum and asking around, I decided on the Lasfit H7 LEDs with cooling fans in them.
What a difference!
The driver's side (North America) was the easiest. Just pull off the dust covers, disconnect the wiring, then push in the spring clip and pull back.
Make sure to note which way the tab is facing. Then pull the bulb straight back and out. Wear gloves when installing the new LEDs they were included with my LEDs. Just reverse install the new ones.
The Passenger side was harder because the best way to do it is to remove the over flow tank for easy access. I didn't drain mine, I just removed the two 10mm nuts and pulled it straight up.
Here's a tip; spray the rubber grommet on the bottom of the tank with WD-40 it will make it easier to remove and reinstall! Once it's out of the way, do it the same way as the driver's side.
I had no error lights and everything works the same as the original halogen bulbs. Just a hell of a lot brighter!
Here are some pics of how I installed the ones on my car.
