Old May 25, 2024 | 01:40 PM
M60A3Driver
Default Re: Cooling fans won't stop running with car turned off
Originally Posted by SirParadox
When you say fan module, any chance you mean the voltage regulator, 3 inch long metal device with fins sitting in the passenger footwell? I’ve had to replace mine twice due to water damage due to overflow from the windshield coming in the fan area. I have a new module but havnt put it in, problem is fan doesn’t go full speed and jumps around, untill today I noticed the fan just will not turn off ever. I’m hoping this module is the fix.
Before you install anything, I would recommend that you clean your drains under the windshield cowl. They're probably clogged and the water flows in the passenger side by the blower motor.
There are a few videos on you tube that show how to do this or you can search the forum.
