Old Jun 11, 2024 | 02:26 AM
M60A3Driver
Default Re: Windshield washers
Originally Posted by richb55
Greetings ,
windshield reservoir is full , pump sounds like it’s pumping , but no spray coming out of nozzles
I pulled off the cowl and a few lines , could not see any thing out of ordinary. I did try to blow thru drivers side with no luck , are the nozzles replaceable ? Any thoughts ???
Thank you
Have you tried spraying with just the feed hose and nothing attached, just to see if the fluid comes out of the feed hose?
The parts are replaceable or you can clean them. I think it's section 8R-30 in the service manual.
The part number is 5099970AA (This is the heated version with the wires).
They are available at Rockauto and e bay.
Rockauto
E bay
