Old Jun 13, 2024 | 08:30 PM
M60A3Driver
Default Re: Another RCM issue-where does it get power?
It depends on the size (there are two different sizes in the harnesses on the RCM). The part I needed was THE LARGER ONE OF THE TWO (see below, I am not sure IF I also had the smaller one part number in the data. Hope this helps!
Part Type: Electrical Pin Connector
Part Number: 0035452626
Interchange: Part Number 003 545 26 26 / 0035452626
Weight: 0.01 lbs
Size: L x W x H 0.2 x 0.2 x 0.6
Part #: 0035452626
Mfg Part #: 0035452626
Interchange Parts for MERCEDES-BENZ 0015453526 (replaced by) 0035452626:
Brand:
MERCEDES-BENZ 0035452626 Contact Sleeve
HERTH+BUSS ELPARTS 50253920 Contact Sleeve
HERTH+BUSS ELPARTS 50253925 Contact Sleeve
VALEO 914123 Contact Sleeve
AUDI 447972980 Contact Sleeve
PORSCHE 99965243712 Contact Sleeve
VOLVO 1212901 Contact Sleeve
VW 447972980 Contact Sleeve
NOTE: EAN: 4026736017002
Another reference part # set:
P/N: 0035452626 Genuine Mercedes
Cross References: 0005452726
0015453526
0015453726
A0035452626
W01331642245
It has been quite a few YEARS since I needed these, not sure if the data is still correct anymore (but) someone could have them, somewhere. Hope someone can use this?
Thanks George!
