Thread: No High Beams
Old Jun 17, 2024 | 01:20 PM
M60A3Driver
Default Re: No High Beams
Originally Posted by Bilbob
I have no high beams. Bulbs are good. What is the most likely problem? Thanks , Bill
Use the flash to pass and see if the high beams light up for a second. You could have a problem with the switch on the column.
Check the fuses located on the driver's side of the dash board by the door hinges.
