Old Jun 21, 2024 | 01:03 PM
zip439's Avatar
zip439
Default Re: Fitting replacement radiator with broken transmission lines
Originally Posted by mp3wizard
If the missing AC condenser fits in those tabs in the last picture, then perhaps the radiator doesn't need to come any further forward?
Negative, The radiator has two tabs at the bottom that fit into metal slots on the car. Thing is for now just to get it running you are fine either way and that is true with the banjo fittings as well. But when you get the condenser for the A/C in there all those tubes will need to be bent properly for everything to fit . I see in one of your pictures the lower banjo fitting tubing is way out of position, but as I say it is fine for now, but eventually if you want an A/C that works you will need to get those all bent and fitting properly.
