Old Jun 26, 2024 | 05:08 PM
ZERACER
Default Re: Interior door pulls
All you need to do is remove the silver cover. It pops in half. To remove the actual pull, there are two bolts under the cover that hold it on. You do not need to remove the door panel.
First on the list is to take apart the two piece door handle using a painters spatula. Carefully wedge and pry the two inner and outer halves apart from the bottom groove of the handle applying moderate pressure.
